Title | Size | Downloads |
03-Layer 2 - LAN Switching Command Reference-book.pdf | 1.21 MB |
Preface
The H3C S5500-SI/EI documentation set includes 10 command references, which describe the commands and command syntax options for the S5500-SI and S5500-EI series Ethernet switches, Release2208.
The Layer 2 – LAN Switching Command Reference describes LAN switching configuration commands. It covers commands for implementing flow control and load balancing, isolating users in the same VLAN, eliminating Layer 2 loops, dividing VLANs, transmitting customer network frames through the public network, and modifying VLAN tags of packets.
This preface includes:
· Audience
· About the H3C S5500-SI/EI documentation set
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with the S5500-SI/EI series
Added and modified commands
Compared to Release2202, Release2208 adds, modifies, and deletes the following commands:
Command reference |
Added and modified commands |
· display counters · flow-control receive enable · link-delay mode up · port link-mode (available only on the S5500-EI) · loopback-detection multi-port-mode enable · mtu (available only on the S5500-EI) Modified commands: · display brief interface is changed into display interface brief |
Added commands: reset counters interface null Modified commands: reset counters interface is changed into reset counters interface loopback |
None |
Added commands: · display interface bridge-aggregation · lacp period short · link-aggregation lacp traffic-redirect-notification enable · link-aggregation load-sharing mode local-first |
None |
Added commands: display stp bpdu-statistics |
Added commands: · mac-vlan trigger enable · port pvid disable |
Super VLAN configuration commands (available only on the S5500-EI) |
Added commands: · display supervlan · subvlan · supervlan |
· isolated-vlan enable · port isolate-user-vlan |
Added commands: · voice vlan qos · voice vlan qos trust |
None |
Added commands: qinq transparent-vlan |
VLAN mapping configuration commands (available only on the S5500-EI) |
None |
LLDP configuration commands |
Some LLDP configuration commands can be configured in Layer 3 Ethernet interface view (available only on the S5500-EI) |
Service loopback group configuration commands (available only on the S5500-EI) |
None |
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
Asterisk marked square brackets enclose optional syntax choices separated by vertical bars, from which you may select multiple choices or none. |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
WARNING |
CAUTION |
IMPORTANT |
NOTE |
TIP |
The H3C S5500-SI/EI documentation set includes:
Category |
Documents |
Purposes |
Product description and specifications |
Marketing brochures |
Describe product specifications and benefits. |
Technology white papers |
Provide an in-depth description of software features and technologies. |
PSR150-A [ PSR150-D ] Power Modules User Manual |
Describes the appearances, features, specifications, installation, and removal of the pluggable 150W power modules available for the products. |
RPS User Manual |
Describes the appearances, features, and specifications of the RPS units available for the products. |
RPS Ordering Information for H3C Low-End Ethernet Switches |
Provides the RPS and switch compatibility matrix and RPS cable specifications. |
H3C Low End Series Ethernet Switches Pluggable Modules Manual |
Describes the models, appearances, and specifications of the pluggable modules available for the products. |
Interface Card User Manual |
Describes interface card appearance and specifications. |
Hardware installation |
Quick Start |
Provides regulatory information and the safety instructions that must be followed during installation. Guides you through initial installation and setup procedures to help you quickly set up and use your device with the minimum configuration. |
Installation Guide |
Provides a complete guide to hardware installation and hardware specifications. |
Pluggable SFP[SFP+][XFP] Transceiver Modules Installation Guide |
Guides you through installing SFP/SFP+/XFP transceiver modules. |
Describes how to install an interface card. |
Software configuration |
Configuration guides |
Describe software features and configuration procedures. |
Command references |
Provide a quick reference to all available commands. |
Operations and maintenance |
H3C Series Ethernet Switches Login Password Recovery Manual |
Describes how to find or recover a lost password. |
Release notes |
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading. |
Obtaining documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical support
service@h3c.com
http://www.h3c.com
Documentation feedback
We appreciate your comments.
